Outil spécial
Outil spécial Empty Outil spécial
Message  Eric Faivre d'Arcier le Lun 29 Juil - 16:37
[img]Outil spécial Dsc_0810[/img]Bonsoir à tous,
Ci-joint la photo d'un outil qui m'a été donné par un ancien propriétaire de 5 HP. Quelqu'un peut-il me dire à quoi il sert ?
Merci d'avance
Eric
Outil spécial Empty Re: Outil spécial
Message  Fer le Lun 29 Juil - 20:46
Quelle est la taille? Peut-etre pour devisser les bouchons des rotules du direction. Ci c'est plus c'est peut-etre une outil pour la 2cv pour demonter le pignon du direction.
Message  Dr Marco le Mer 31 Juil - 0:45
I think this tool is used for the ring on the ball bearings of the transmission axle. I have been struggling to unfasten this for over two months now and am considering constructing one myself.
Sorry for replying in English.
Marco
Dr Marco
Message  Eric Faivre d'Arcier le Mer 31 Juil - 9:50
Thank ,you for reply. Can you precise the part number of these ball bearings on description plate of Willy Shaffoth site ?
Best regards
Eric
Message  Dr Marco le Jeu 1 Aoû - 0:17
Dear Eric, it looks like something thats fixing part number 10486 on plate 6 in the 'pieces detachees'. I will make a picture of it when I return home in another two weeks and also try to find it in my hard copie of the parts list or the technical manual.
Dr Marco
Message  Fer le Jeu 1 Aoû - 17:22
tu pense celui la, c'est plus grand a mon avis. L'outil c'est au milieu.
Outil spécial Outil
Message  Dr Marco le Ven 2 Aoû - 8:50
No, I know this one. I wished I had had this one as well. As I also had quite a problem taking one of these off the axle. Fortunately the local smith was able to help out.
The thing I meant is on the main driving axle, right behind the the flexible part connecting to the gear box. I am sorry not to be able to use the proper french description, but if you have some patience: I will be back home in 1,5 weeks, making a picture of the part and sening it to you.
I should then also update my progress on this forum, as after quite a bit of work my 5HP is now in the rebuilding stage. (chassis, fueltank, wheels, and every thing else attached has been sanded and painted again).
Dr Marco
Message  Dr Marco le Jeu 15 Aoû - 11:44
Dear Eric,
This is the picture I had in mind. If you could specify the diameter of the tool and the size of the dents I can definitely tell you if it fits.
Outil spécial 20130814
I still haven't succeeded in loosening this one. It is necessary however, as there is considerable wear visible in the bearings.
Dr Marco
