Machoires de frein
Machoires de frein
Message  m gosset le Jeu 11 Jan - 7:21
Notre ami Charles Grant au Canada recherche
deux  mâchoires de frein
Il nous dit qu' il est tres content de sa magneto
Merci d' avance
De Charles Grant A m gosset, Hier à 23:50
I recall that you very kindly offered to help me with correspondence in French on this site.
have been busy with other car projects but I am now trying to rebuild/ reline the brakes on my 5HP.
I have tried to purchase some new shoes from 4A Sarl.-They are out of stock.
The problem I have is that two of the shoe casting are broken - probably beyond repair.
I would like to put a request on the forum to see if I can get two brake shoes that are usable.
I have the lining and rivets ready to install.
The magneto rebuild was just what the car needed - runs very well.
I have recently bought a 1973 D Special , drove it from Montreal to my home here in Nova Scotia - about 2000km.
Transmission was noisy so I took the engine out and replaced one bearing in the transmission but most of the noise is still there.Too cold to work in my garage now so working on small projects indoors.
So - if you could post my search in the best place on the forum I would appreciate it very much.
Thanks
Grant Slinn
Annapolis Royal , Nova Scotia
Charles Grant
Dernière édition par m gosset le Jeu 11 Jan - 8:58, édité 2 fois (Raison : correction semelles / machoire)
Re: Machoires de frein
Message  amicale5hp le Jeu 11 Jan - 8:13
Michel,
Semelle de frein, tu veux dire garniture ou mâchoire ??
Message  m gosset le Jeu 11 Jan - 8:46
Machoires ! J’ y perds mon latin !
Merci JP
... au fait , il y en a chez Willy Schafroth a Polyparts :
http://www.polyparts.ch/oldie/citroen-5hp/fr/echanges_standards.htm
Message  Fer le Jeu 11 Jan - 9:04
pas mal pour une exemplaire complet.
machoire de frein
Message  tréfle le Jeu 11 Jan - 13:30
attention ces pas le prix de la paire ces e l echanche standard faut fournir les anciennes mâchoires ces juste une réfection je pense que le prix de la photo ces une mâchoire pas la paire
Message  moulino51 le Jeu 11 Jan - 16:09
Oui, "Mâchoire" au singulier
Message  m gosset le Jeu 11 Jan - 16:23
Traduction du message de Trefle plus haut:
Translation of Trefle's message above :
The Polyparts offer is on a standard exchange basis ; Price is for one shoe only .
Par contre cette offre de Retropieces semble etre pour une machoire d' occasion
However this Retropieces offer seems to be for a second hand shoe
Message  m gosset le Lun 15 Jan - 18:58
Hello Charles
Notre ami Espagnol , Julio Ubierna de Burgos me dit qu ‘ il a un jeu de repliques de machoires en acier . Apparemment de bonne qualite , elles etaient installees sur la transmission mais sont identiques a celles des roues arriere.. Il en fait cadeau !
Our Spanish friend on the Forum, Julio Ubierna from Burgos , tells me that he has a set of replica brake shoes made of steel. Apparently they are well made.They were installed on the transmission but they are identical to the ones on the rear wheels.
He is happy to give them
Here are the photos
Best regards
Message  Fer le Lun 15 Jan - 19:25
Bien fait mais il y a besoin de autres ressorts en haut. Mais ca ne doit pas etre une grand problem de trouver un jeu d'une autre voiture.
Message  m gosset le Mar 16 Jan - 9:23
... en effet apparemment les trous de fixation des ressorts et les ressorts sont differents entre les deux montages.
... indeed the holes in the shoes and the springs are different depending whether the shoes are istalled on the transmission or wheel
Message  amicale5hp le Mar 16 Jan - 9:43
Je confirme, il y a deux modèles de ressort.
Je ne sais pas actuellement chez dépanoto ,mais il avait un seule modèle, qui était trop grand pour les tambours arrières.
Si, des gens ont besoin ,je peux voir pour en faire refaire? j'ai un fabricant a côté de chez moi. Mais pas moins de 100 pièces.
Jean ¨Pierre
Message  m gosset le Mar 16 Jan - 10:45
Le catalogue Retropieces propose des ressorts de 46 mm
...mais d’ apres www.citroen-5hp.ch ,  les longueurs sont respectivement de 40 et 52 mm ..
